GreenAce92
Member level 4
- Joined
- May 6, 2010
- Messages
- 70
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Buffalo, NY
- Activity points
- 2,032
This might be easier since it is stationary.
I was thinking about a clamp-on IR beam-blocker which I would place a black sticker on the rim, and assuming the shiny part of the rim reflects, then I should get a difference between non-sticker, and sticker part of the rim.
I would then use the measured radius from the hub to the sticker to calculate rpms right?
Do you think that the IR reader can get a good enough threshold/range/difference between bounce/no-bounce?
So with the shiny part it's bouncing same rate, then hits the black part, should absorb some of the waves... this sounds like a bad design
Maybe a spoke-clip on thing that reflects the signal back to the emitter.
