what will be the voltage!
aj_silverthunder
Full Member level 3
Full Member level 3
asia
1) in this case batteries r connected in parallel combintion so current will increase (current = Battery1 + battery2) & voltage remains the same
2) it will be 18v bcz batteries r in series combination & current will be equal to the lowest current of the battery.
3)Current increases in Parallel combination
don't forget to click on helped button
so then if i want 18V power source then i have to connect the two 9V batteries in series configuration!
