what waveform viewer is used for spectre (cadence 5.0 linux)
Vitamin-C
Member level 2
Member level 2
cadence waveform viewer
as title,
thx in advance,
vita
spectre waveform viewer
There is a build in waveform viewer for IC5033.
wavescan waveform viewer
you can use two of them - waveform viewer and wavescan
spectre cadence
thx for your replies,
If I run spectre in command line, how to invoke the waveform viewer.
I have tried AWD which can't read the waveform output,
also I don't have wavescan installed ...
vita
waveform linux
No idea how to run it from the command line. Always use analog artist. Why don't you use it, too?
cadence linux waveform problem
I have used SpectreRF, but there is a built-in waveform viewer...
cadence analog waveform display
How to switch between each of them ?
linux wave viewer
Give awd command in the psf dorectory which pops up a result browser window. click on the analysis you have done and then the net you want plot. This will load the net into the calculator. then you can click on the plot button of calculator to view the results.
awd spectre
In IC5141, the default is wavescan.
How to force awd (or spice SpiceExplorer) as default ?
cadence view waveforms
u should copy three files such as artistLogFile,runObjFile and variables-file to psf directory and u can view waveform with AWD. And the three files are produced by first running spectre for any simple circuit in analog artist. :p
spice waveform viewer
But my problem is : how to have awd as a default viewer inside Cadence?
If I run a simulation and plot them during simulation, I want to see them in awd (or spice explorer) not wavescan.
cadence 16 viewer
You can choose the option of analog waveform display, which is available under the analog design envirnoment window.
wavescan cadence
Session -> Option menu
There should be an AWD viewer selection.
