What value should I set on wire_load in .18 process(tsmc) ?
cloudsuns
Newbie level 2
Newbie level 2
wire_load
Hi ,everyone
what value should I set on wire_load in .18 process(tsmc)
Re: wire_load
Can you give me more detail description about your question?
The wire_load must be set based on the size (gates in design)of chip and the library.
Re: wire_load
why not try physical compiler to avoid this arguelessness question?
Re: wire_load
A good rule of thumb is for the estimated wirecap per fanout to be the same as the input gate cap of the largest inverter using a single P and N transistor. If you've got lots of gates, or are simply cautious, you can increase this value by say 50%.
-Graham
Re: wire_load
hi,
dont try to estimate the wireload under 0.18um , using pc
Re: wire_load
I agree, below .18 real environment should be considered for delay calculation. If you still use DC, your convergence cycle will be enlarged, and many many useless buffer, inverter will be introduced.
Then which kind of eda tools should be used in < .18 design?
Re: wire_load
Phsical compiler
