Wolfgang Kuehne
Newbie level 3
I had an old useless shaver so decided to do some trick with it. The battery within the shaver was over (it could not be recharged anymore). Moreover it was a battery which can not be removed. So I decided to change the circuit and leave the battery out of the game. I connected the adapter of the shaver directly to its motor. However, this time the device did not have enough power to move the blades. Why?
So I took the adapter out of the game and decided to use an iPhone charger instead.
Currently the device takes its electricity from the iPhone charger, over a usb cable, who's cables are directly connected to the motor. At the moment the blades move with a very high speed, which I consider that will damage the device pretty soon. As well the motor turn that fast, that I can not keep it in my hand due to the vibrations.
I thought it would be OK to put a potentiometer to the whole setup to be able to control the speed of motor, but I have no idea what type of potentiometer to use, and what range of resistance.
In case of need provide the following details:
Not used parts:
The original adapter:
AC-DC
AC: 220V - 240V - 50Hz
DC: 3V 700MA
Battery withing the device:
It is AA, 1.2 volts, 1000mah
The setup as it is now:
According to the info here: https://discussions.apple.com/docs/DOC-3511
The iPhone charger has: 5 volts 1.0 amps 5 Watts
What should be the range of the potentiometer? Please help!
Thanks in advance,
Best,
Wolfgang
Not used parts:
AC-DC
DC: 3V 700MA
Thanks in advance,
Best,
Wolfgang
