If you send the signal to the non-inverting input, then the signal must come through some amount of resistance, in order for the hysteresis to work reliably.
Or if you wish you can send the signal to the inverting input. It depends on whether you want the output to be inverted or not.
Since your op amp is labelled 741, remember that the 741 output does not go below 2V, when powered from a single supply.
okk sir thanks , You have shown here tw0 presets in the diagram but values are not mentioned , please tell
the output changes accordance to the the input of I.R. rays on the photo diode
kkk sir you mean to say the resistor at pin 3 (100k) in series wih 68k from the output ?
