when I genearte RF2R2W power, I get I=5mA, worst case V=1.62v 200Mhz,so the power should be 5*1.62v=8.1mW, the value in the library should be 8.1/200=0.0405 mw/MHZ, I checked the compiled library it should should be 40.5, what the unit should be in compiled library ?
the power dissipation is connected also with the switching activity and the capacitance. Check your library there is an equation for power estimation. It is not that straightforward.
It meas short_circuit power.
During switching, a circuit dissipates internal power by the charging
or discharging of any existing capacitances internal to the cell. The
definition of internal power includes power dissipated by a momentary
short circuit between the P and N transistors of a gate, called shortcircuit
power.
I don't think that there is a reason for you to build a library with the short circuit dissipation of several digital circuits. If you the rise time and fall time of the gates are equal then the short circuit dissipation is minimized. I can cite you to a paper if you need further informations.
Sorry,I am a little confuse of that. For a cell internal power may meas short circuit power,but for a circuit compose lots of cells, they are not the same definition. In my opition,it may meas dynamic power.
I have ftp some files ,include library and verilog code .It generate by memroy compiler. Please see the library file, the internal power problem is in there. thanks.
