Fom said:for hysteresis
sankudey said:I feel - by sense you are correct, this is to increase gain. Actually, it is in +ve feed-back configuration and if you can break their latched state (which the previous post called as hysteresys), it will go to the other direction for any any error signal. This is what is required in comparator. For a Gain of "A", which is constant, you will find some error voltage when the output fall sort of rail. For this positivge feed-back configuration, you will get an output always at rail voltage.
