What running condition is needed for this code?
adscrz
Member level 1
Unknow
Running condition
reg [1:0] xmitDataSelH;
reg [7:0] xmit_ShiftRegH;
always @(xmit_ShiftRegH or xmitDataSelH)
Which codition will been need to run this always ?
Is the value of xmit_ShiftRegH or xmitDataSelH changed?
ThX.
Running condition
yes.
obviously right.
Running condition
First thing is your question is not elaborate,....,
always@( sensitivity_list),....,which you wrote is used to run always for a change in the reg/wire specified in the sensitivity list.
If you want to run for a repetitive period, then use a clock, which should be mentioned as, always@(posedge clock).
Let me know, if something is confusing. Also, write ur question in detail, if you want to know more about your doubt.
thanks,
-reddy
Re: Running condition
yes, you are right,
when xmit_ShiftRegH or xmitDataSelH change value,
this always block is executed.
ThX.
It can be either xmit_ShiftRegH or xmitDataSelH or both. If any of these conditions exist then the statements with in the always block will be executed.
