What ports does Windows 2003 VPN server use ?
verilog_crack
Full Member level 2
Full Member level 2
In the Sky
VPN
Hi all
I want to connect two LAN networks together via VPN tunneling, but I have a trouble, each of LAN network is behind a router with valid IP, and computers behind the router are connecting to the internet with invalid IP.
Because in this case I must set VPN server on a computer with invalid IP, I don't know how a VPN server answers to VPN client's request. So Pls tell me.
And another question is that, does VPN server listen to an especial port? (Such as FTP which listens to the TCP port 21.)
All notices are welcomed,
verilog_crack.
Re: VPN
If you want to setup a tunnel then 1 endpoint must have a non rfc1918 address...(you call it valid..don´t know why ;o)
There is no way setting up a tunnel between two endpoint with rfc1918 addresses...you need at least one external server running as tunnel endpoint...or you know the network admin who can open a dedicated port on the firewall to do port forwarding to your PC´s (o;
I suggest you look around for http tunneling...
also it depends what OS you´re running...chances are better running UNIX (o;
Re: VPN
I know all of what you said.
I can forward few ports from router to my VPN server but i don't know what ports does VPN server use?
can you help me with giving port numbers to me.
thanks
Re: VPN
What vpn server?
There are probaly dozens of different vpn implementations..you have to choose what's best for you...
Hi
Ok, I want to use Win2003 VPN Server
Can you help me?
Or would you mind introducing me a good VPN Server in windows.
Regards
