What PIC to use for USB interface with PC?
ericmar
Full Member level 5
Full Member level 5
Singapore
Wat PIC can I use for building an USB interface device that is connected to the PC. This device basically just send a signal to the PC when there is input. Besides, I'll need to use a LCD with this device to show information.
Re: USB interface with PC
You can use the 16C745/765 devices though they are only low-speed....but okay for your application...done a test application for OSX once with the sample code from their website...
And remember...the USB device never informs the PC about data!!!
The PC always asks the USB device if it has something to send (o;
And DO NOT POST same questions in different topics...or similar question like your coin-detector...
Hi, thanks for ur reply. I'm sorry abt posting the same thing in different topics because I dont know where it should goes to actually.
BTW, may I know do I hv to write the device driver by myself? Is it very hard? Someone told me that it takes long time and it's nightmare to a newbie. So I only has some experience with the parallel port and it seems that I cant do the USB like parallel port by just using the .dll library file. Is that true?
look here h..p://www.codemercs.com -> io-warrior
You can use a 90S2313 for emulate a usb port.
The ci cost 10 Euro.
Take the url : http://www.cesko.host.sk/IgorPlugUSB/IgorPlug-USB%20(AVR)_eng.htm
here is the nice artical may help you
