what motor has the highest speed and tork (weighs<=1kg)
nafaiz
Member level 5
Member level 5
Malaysia
can anyone tell me which motor has the highest speed and the highest tork...that means it can carry heavy things at high speed.
there is no specific standard but the torque is normally mentioned on the motors
if you do not require accurate positioning simple dc motors should do ; you could use gear systems improve the torque
or else you could you stepper motors
they have high torques but have speed limitations
You should check out some r/c car motors
They will cost anywhere from $20 USD to $80
