yolande_yj
Full Member level 3
- Joined
- Jan 20, 2005
- Messages
- 152
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 1,647
The mixer design contains a lot of balances. I know the spec is largely depend on the application, but there should be some commonsense there. For example, when designing LNA, we say a -10db S11 should be garentee, a NF less than 2 is good, the gain is more or less around 20dB (narrow band) and a reverse isolation of about -30 db is acceptable ....
For downconversion mixer (frequency from 1.6G to 10MHz), can you add your comment like this? Or what do you think the spec inside the bracket?
Application: (Low IF receiver)
Process: (SiGe)
Structure: (Single Balance active)
Power: (1.8V x 2mA)
Conversion Gain: (2 db)
P1dB: (-10 dbm)
IIP3: (3 dbm)
NF: (8 db)
Output load: (1k ohm)
LO to IF isolation: (-30 db)
Process: (SiGe)
Power: (1.8V x 2mA)
P1dB: (-10 dbm)
IIP3: (3 dbm)
NF: (8 db)
