metiz
Junior Member level 1
Can anyone help me identify this resistor? It's not a weird one, I just **** at electronics. If read from the isolated brown band down, I get 180 ohms, asuming that silver band isn't gray. Can anyone confirm?
Or brown-black-black-silver gray brown, 1.00 ohm 0.05% 100 ppm. But 0.05% tolerance with 100 ppm TK would be about to useless.
Measure it with your DVM!
Frank
Maybe it was used as a fuse and it has blown because there is still a fault in the circuit. Then a replacement resistor will also blow or the circuit will smoke.
