What kind of industrial network is SERCOS?
epp
Full Member level 5
Full Member level 5
SERCOS
Thanks.
Re: SERCOS
Check w*w.sercos.com web site.
Generaly sercos use AC servo drives for comunication.I use sercos link with indramat and Hitachi ac servo drives.
w*w.st.com have sercos chip.But I dont remember ic number.
And below Hitachi sercos ac servo databook
    epp
Re: SERCOS
h**p://w*w.hiflexonline.nl/documentatie/pdf.zip
Which other networks could be used also with AC drives?
Re: SERCOS
Ac drives use rs485 and profibus network
Ac servo drives use generaly sercos and some special own links (Omron,seie,baldor,,,)
Re: SERCOS
for: Fuzzy
I have use Indramat Servo Control type Hardware : CLM-01.3-A-0-1-0
Software : LA-01.3-002
I have trouble after power on, "System Failur ! Code #EXCP24" on LCD display
can you help me..?
thank's
Re: SERCOS
I hope next week may be write.
I know CLM but I dont use.But I have all documents.CLM old system but very strongly.I use SYNAX and VISUALMOTION.
Re: SERCOS
I send a message for your problem.And Indramat send this message.
Hello Serdar, it again to some extent goes. EXCP24 is a Exeption error by the microprocessor of the CLM is spent. The error can be caused by disturbances if for example the 5V-Versorgungsspannung is disturbed or if disturbances over the raster entrance to come. If you do not find in this direction anything can it also be that the CLM are defective. Exchange of the control
regards
Mr.Serdar Cetin
dizayn@efes.net.tr
