danny davis
Banned
What kind of circuits output a number of pulses before it goes into a low state? what kind of circuit's is this called?
What Component determines the number of pulses? is a counter or clock , or timer the only options?
a.) use a counter , but how do u get the counter to only output 20 pulses before it went into a low state?
b.) use TIMER, but how do u get the Timer to only output 20 pulses before it went into a low state?
c.) What can I use to ENABLE an Op amp input or a Comparator input to only output 20 pulses before it went into a low state?
d.) What can I use to ENABLE a Transistor or FET was a "switch" to only output 20 pulses before it went into a low state?
e.) Use A clock , but how do u get the clock to only output 20 pulses before it went into a low state?
What is an RC network that has Diodes called? the diodes are to discharge the RC network really fast
Can you make an Counter or Timer from an RC network that has Diodes to do the discharging? a Passive RC network with Diodes configured to be a counter or timer? to only output 20 pulses and then it goes into a low state?
Example#1 circuit
Pulse period = 1 second
Number of pulses = 20 pulses = 20 seconds
Total time of pulse train = 20 seconds
Output goes into low state after 20 seconds
Example#1 circuit
