eejli
pll loop filter
Dear Folks,
I am testing my PFD, charge pump and loop filter. They are connected in series.
As shown in the attached figure, the loop filter voltage drop down after the increasing ramp when "UP" signal =1. Where does this voltage drop come from. I am using ideal resistor and even the ideal charge pump (veriloga model).
I guess it is from the loop filter time constant. I am using a big cap, 72 uF. How can I avoid this big voltage drop since I found it cause problem for my PLL locking? In the lock process the loop voltage cannot increase at all after several micro second's settling.
Thanks!
Dear Folks,
Thanks!
