What is wavelet transformation?
comm_eng
Newbie level 3
Newbie level 3
i wanna know what is wave-let transformation?
Re: what is wave-let?
It is a way in digiotal dignal processing, which is based on smal wave(wavlets).
The wavelet transformation (opposed to the furier transform) give you a good localization in both frequency and time. The difference between the short time ( or window) fourier trasform and wavelet it that wavelet uses "windows" of different sizes and not only one window like the short time furier. It is also more numerically efficient then furier.
    comm_eng
what is wave-let?
the window function used in wavelets allows better analysis on real-time signal or signal that changes with time.
i had my project using thedicrete wavelet transform and these r the best link i ever came across..njoy!!
what is wave-let?
Hi
If your field of interest is electromagnetics,this is a nice reference below.But Wavelets are used in
Digital Signal Processing much more and there are a lot of books about it in Signal Processing.
h**p://www.amazon.com/exec/obidos/tg/detail/-/047141901X
what is wave-let?
I have a short explanation for EE who know Fourier Theory and want to know Wavelet.
In Fourier, we know any signal is combined from infinite sum of sine and cosine at different amplitue and frequency.
In waveletm instead of sine and cosine, It is something call mother wavelet that have the wavelet properties. It means each signal can have it own basis wavelet function.
So, in theory.. you have a signal. search through its data and find the best mother wavelet. the keep the coefficients (compare to amplitue&harmonics of fourier)
That's why wavelet compression is better. (you choose the best function, fourier must be sine/cosine)
hi
you can refer to "introduction wavelet " by D. walnut
and "a freindly guide to wavelet" by kaiser
bye
hi
Wave-let is a transform as laplace transform or foureir transform
bye
