What is VLW window function after running DRC or LVS?
eng_Semi
Full Member level 6
Full Member level 6
Egypt
assura drc vlw
Hi ALL,
After running DRC or LVS, a widow appears called VLW.
What is its role ??
Regards,
eng_semi
Re: VLW window
The VLW contains all the layers used by Assura in the drc file. Look at this file and you'll understand.
It is usefull when you don't understand an error.
It is also usefull to create your own LVS or DRC file.
Franck.
Re: VLW window
VLW is the View Layer Window which appears when you are trying to view your DRC results.The VLW controls the verification colors you display on your screen.
This window displays layers used by assura. The colors in VLW are assigned by assura and may not be same as the original layout.
