What is Vin (min) of ZXGD3003 gate driver IC?
T
treez
Newbie level 1
Hello,
ZXGD3003 Datsheet...
Datsheet doesnt give Vin(min)...do you know it?
Vin is your gate trigger pulse (from microcontroller or some other digital source)
Vin (min) = 0V
Vin (max) = vcc
Reactions: treez
    T
Thanks, but all IC's have a min operating voltage , below which they do not operate.....and this is not stated in datasheet.
What voltage will you use it with? One thing's for sure - it will work at 12V all the way up to 40V. The graphs all show VCC=12V.
According to the switching test diagram, it seems like, all this driver is, is a a totem-pole driver with high current rating. In that case, it should work at 5V as well. But if you're driving Power MOSFETs, don't go below 8V.
Hope this helps.
Tahmid.
Reactions: treez
    T
