What is timeborrowing related to Static timing anaylsis?
davyzhu
Advanced Member level 1
oriental
timing borrow
Hi all,
I was asked in a interview, but I am not familar with Primetime.
"What is timeborrowing related to Static timing anaylsis in Primetime?"
Any suggestions will be appreciated!
Best regards,
Davy
latch static timing
if u have a latch in your design and you are not using one full clock cycle for the latch... you could use the unused clock period for next or previous combinationl logic.. this idea is called time borrowing
refer this page too
    davyzhu
timing given borrow
borrow time from neighborhood stage
for example, the delay between two fllip-flops may be too long, but the delay between next two flip-flops is very short, so time can be borrowed from the next stage
timing borrowing
It's a synthesis function instead of timing analysis.
timing-borrow
Hi all,
What's the difference between "Timing borrow" and "Retiming"?
Best regards,
Davy
timing borrow
timing borrow, we refer to use latch to borrow time, which is typically half a cycle.
retiming, is to move register forward or backward through the combinatorial logic to balance the timing paths on every stage in the nearby register chain.
    davyzhu
what is timing borrowing
how to use latch to borrow time?
thanks & best regards
timing borrow in sta
As i know, in the physical implementation such as P&R can use the timeborrowing to relieve the crucial path Using the ECO
static timing balance
time borrowing means, one latch takes time of its neighbour latches, if the neighbour latches doesn't have timing violation.
Retiming means, placement of the sequential cells will be done by the tools in such a way that, they doesn't lead any timing violations.
violation latch borrowed
Timing borrow happened at Latch? so gate-level netlist u synthesis include Latch? Then ..P&R tools can borrow timing ?
latch static timing analysis
half latch to flop timing paths
Generally, 'timing borrowing' is to use latch's behavior to make slack of previous stage or next stage met according on max. borrowing or balanced borrowing.
Other STA tool also provide 'pass-through' mode for timing analysis in latch designs, such as Incentia's TimeCraft.
Regards;
pdf latch based static timing analysis
Hi
Can anyone help me understand "what is negative time borrowing "
thanks
Isis
