[SOLVED] What is this component? dw234
fouwad
Full Member level 4
Full Member level 4
Pakistan
This is the image of a component on an old circuit board, i am unable to find its datasheet or any other info, please let me know if anyone has any idea about it. Thanks
Hi Fouwad
here you go.. 2DW232 and 2DW234 are from same family. hope this info helps.
  • Product Name: Silicon planar temperature compensated voltage reference diode
  • Model: 2DW232
  • Product Features: Metal housing, small temperature drift
  • Technical parameters:
  • Vzmin: 6.0V
  • Vzmax: 6.5V
  • IzR: 5mA
  • Rz: ≤ 10Ω (Iz = 10mA)
  • Izmax: 30mA
  • αvz: ≤ 5 10-6 / ℃ (I = Izt T1 = 25 ℃ T2 = 75 ℃)
  • Tamb: -50 ~ 150 ℃
  • Tstg: -50 ~ 150 ℃
  • Parameters: (Tamb = 25 ℃)
  • IR1: Vz = 1V Imax = 1μA
  • IR2: Vz = 1V (Tamb = 100 ℃) Imax = 10μA
  • Typical Applications: used in electronic equipment, instrumentation precision voltage source or a reference voltage source
  • Packaging: Metal packaging
Reactions: fouwad
    V
    fouwad
Thanks alot for your help, but my question is what is the difference between DW232 and DW234 as you posted data for 232 while i want to know info regarding DW234
Hi
Reactions: fouwad
    fouwad
all the properties are same except (IZR: 10mA) for DW234, **broken link removed**
as mentioned by embedsys!!!
Cheers!!
