perezalvarezhi
Newbie level 3
- Joined
- Nov 24, 2012
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Guadalajara, Mexico
- Activity points
- 1,309
I want to know what is the sequence that a windows 7(x64) machine(its an Asus motherboard just in case it is dependant of Motherboard manufacturer) follows when shutting down with respect to hardware.
Im making a project that uses an USB AC relay controller to switch a contactor (a switch with a coil) which gives power to the computer, basically it lets me turn on the computer using a button outside of a big industrial cabinet.
I just want to make sure that the USB is the last thing to loose power since the moment the USB looses power the contactor will not let energy flow to the PC and the hard drive might be damaged if it is not yet turned off.
Thank you for you answer!
