Solution is wrong. About 0.86 mA If.
No "complete model" is given in your post.
Two rough assumptions (without explanation) - and a result with a pico-volts accuracy.´?You can replace the diode with a 10 ohm resistor and a 0.7 volt power supply. Then a equation should be solved to find the Voltage across the diode which is:
(-690) / 998 = -0.69138276553
Yes. The OP is apparently assuming 0.7V with 10 ohm series resistance as model, without stating this explicitly or even a substantiation. In this case, the exact current would beNo - without any further information, we have no other chance than to ASSUME 0.7V across the diode and find the current through the diode (method of node voltages): Id=0.86mA.
