[SOLVED] What is the use of UART terminal in proteus?
rado
Member level 2
I am using Proteus for simulation and micro c for hex file generation, is there any option to verify my code with out going to hardware?
What is the use of UART terminal in proteus? and also in micro c?
Can i use them for my purpose?
how to use them?
I am using pic 16F877A and 434MHz transmitter and Receiver. I need to send a code like ' START ' to run a 7 segment display counter and a motor.
I have done the simulation and succeeded, but transmission and reception part remains.
Can anyone help me with the required micro c code for transmission and reception? It will be a great help.
could i use HT12E or HT12D pair?
:roll:
Re: RF Transmitter and receiver interfacing with PIC16F877a
if you use ht 12 e and 12 d then it will become simple to do because the ic converts simple parallel 4 bit data into serial data.
yes atul it will become simple. But i want to know that, if their voltage requirements could be met with the output voltage of pic16f877a?
Use this attached Proteus RF template file for RF projects. Change the micro-controllers to yours.
  • Proteus RF Template.rar
first of all thanks for your attention sir.
i replaced that pic with Pic 16F877a which iam using.then loaded with the following micro c codes, just to try
a transmitter side
Code C - [expand]
void main() {
int dat;
UART1_Init(9600);
dat=25;
delay_ms(100);
UART1_Write(dat);
at the receiver side i used these codes.
Code C - [expand]
8
void main() {
int dat;
UART1_Init(9600);
delay_ms(100);
if(UART1_Data_Ready() ==1)
dat= UART1_Read();
i actually meant to send the data 25 and receive it
but nothing is displayed on the uart terminal.
actually how could we use this uart terminal in proteus?
could we see the transmitted and received data?
I need to transmitt a code like start and at receiver side it is recognized and then run a motor.
should i use array?
Try these codes.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
//Tx code
char uart_dat = 25;
void main() {
    TRISA = 0xFF;
    TRISC = 0x80;
    PORTA = 0x00;
    PORTC = 0x00;
    UART1_Init(9600);
    Delay_ms(100);
    while(1) {
          UART1_Write(uart_dat);
          Delay_ms(2000);
//Rx code
sbit LED at RD0_bit;
char uart_rd = 0;
void main() {
    TRISA = 0xFF;
    TRISC = 0x80;
    TRISD = 0x00;
    PORTA = 0x00;
    PORTC = 0x00;
    PORTD = 0x00;
    UART1_Init(9600);
    Delay_ms(100);
    while(1) {
          if(UART1_Data_Ready() == 1) {
                uart_rd = UART1_Read();
                if(uart_rd == 25)LED = 1;
                else LED = 0;
                uart_rd = '\0';
nothing was displayed on the virtual terminal sir.
sorry for the delay to reply
Maybe you selected wrong crystal type and or frequency in mikroC or in Proteus or wrong baudrate settings for VT in Proteus.
That was the reason sir, my virtual terminals baud rate was different.
now i could see the transmitted and received data.
now what to do to send a data like " START "? should i use a string?
then in practical case there could be a problem by the noise.
By using this function UARTx_Read_Text(char *Output, char *Delimiter, char Attempts);
in UART library, and sending repeatedly the data, will my problem get solved?
At Tx you have to use
Code C - [expand]
UARTx_Write_Text("START$$");
The read text function at Rx side should check for "$$" delimiter. Keep baudrate low like 600 bps.
Reactions: rado
    rado
Hi, i tried the code for the same baud rate 9600 and found the response correctly.
As i already said i need to use this as a start command to run a counter and dc motor , whose simulation had completed successfully. now i added the two simulations together. so Sir i will come back with my doubts, so please keep your kind mind to help me.
Sir i used this code for verification
but it shows an error, when i writes uart_rd == " STOP"
i had initialized uart_rd as char type
what is going wrong?
if i give uart_rd == 25 it is compiled successfully but i want to check that a STOP is received or not
how will i do this?
               // uart_rd = UART1_Read(); this is a comment
                  UART1_Read_Text(uart_rd, "$$", 15);
                  if(uart_rd == " STOP") portb.f0=1;
                  else portb.f1=1;
Your code is wrong.
char is one byte wide. You need string.
Try these... Use 'S' for Stop and 'R' for Start (Run)
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
//If Tx is sending 25
unsigned char uart_rd = '\0';
        if(uart_rd == 25)PORTB.F0 = 1;
        else PORTB.F0 = 0;
//If Tx is sending "STOP"
char uart_rd[];
char cmd1[] = "STOP";
        UART1_Read_Text(uart_rd, "$$", 6);
        if(!strcmp(uart_rd, cmd1))PORTB.F0 = 1;
        else PORTB.F0 = 0;
i had started doing the project on breadboard, that counter+ dc motor part, It's simulation in Proteus was correct and i programmed the pic with corresponding program [ hex file obtained in micro c ]
i connected my pic 16f877A's clear pin to +4.8v,put an 8MHz crystal between pins 13and 14 which is for osc in and out respectively. i connected the VSS pin to ground and VDD pin to +4.8v
but the output pins give a voltage of .03v what happened?
my code is
void main() {
int i,j,k;
TRISB =0;
TRISD =0;
TRISC =0;
PORTC =0;
if(PORTC.F5==1) goto check
else portc.f5 =1;
for(i=5;i>=0;i--)
PORTB =i;
 for(j=9;j>0;j--)
PORTD =j;
delay_ms(80);
PORTD =0;
delay_ms(80);
PORTD.F6  =1;
  check: PWM1_Init(1000);
PWM1_start();
PWM1_Set_Duty(125);
if (PORTB.F0==0)
{ repeat:PORTB.F4 = 1; //Run motor in clockwise
 delay_ms(170);
 PORTB.F4 = 0;
 TRISB.F6 = 1;
 if(PORTB.F6==1)
 PORTB.F5 = 1; //Run motor in anti-clockwise
 delay_ms(170);
 PORTB.F5 = 0;
 delay_ms(500);
 goto repeat;
  else PORTD.F7=1;
  if(PORTD.F7 =1)
  {PORTD.F6 = 0;
  portc.f5 =0;
hi, I also started a new thread on this topic and you had responded to it.
thread name is using pic microcontrollers.
Post your exact circuit.
sir my circuit and codes are these
PROTEUS simulation is in 7 seg
and code is in 7segment
sir my another doubt is,
for my project i first sends a code to run the counter and then a motor [ used code is S means start , this transmission and reception works finely ]
if everything goes fine, then i will send a code back [ i used P means pass ] , i could see the transmitted signal, that is P.
but at receiver, it shows the first code ie S. Transmission and reception are between two points.
the problem is the receiver, which should receive a P is now receiving S .
  • 7seg.rar
  • 7 segment.rar
Your code is difficult to read as it doesn't have indents. Also you were advised not to use goto statements.
If your are using 434 MHz RF modules are similar which doesn't have address detection then you need to send data like this...
Tx1 sends data to Rx1 like Tx1S
Tx2 sends data to Rx2 like Tx2P
If you just send S and P then S sent from one Tx is received by all the other Rx.
yes sir , I am using a 434MHz RF transmitter and receiver. How this type addressing possible, sir? should i use that delimiter case? i mean the function, UARTx_Read_Text(char *Output, char *Delimiter, char Attempts);
send S1 ,then put delimiter as 1. I will try this option , if there is another right way, kindly redirect me to that.
