What is the unit that FEMLAB axis uses in drawing?
dkmin96
Hi. Please somebody would tell me what is the unit of FEMLAB in drawing?, for example mm, cm, m, etc. What I know is just FEMLAB use meter(m) in basic unit. Is it right?
I'm trying to draw microstrip to check s-parameter. But the result is not correspondant to transmission line theory. I doubt a unit in FEMLAB. As you know there is no way to see unit. version is 3.2. Thanks in advance.
Re: FEMLAB axis unit
Hi dkmin96,
I have had the same problem the first time I have used FemLab! :)
The answer is: "meter". All units used are SI-units in the calculation.
best: Ricy
    dkmin96
