ElectroZ
What is the standard isolation voltage between top & bottom layers in 1.6mm FR-4 PCB?
What is the standard isolation voltage between top and bottom layers in a 1.6mm FR-4 PCB?
I need to route some 230V/380V AC lines to the PCB and some parts are quite difficult to route single sided while maintaining adequate distance between tracks.
So is it OK to use top side of the PCB for neutral tracks and bottom side for the live tracks? Or yet, one side for the low voltage logic and other side for the high voltage?
