the technology section from the files specified in the Tech LEF Files box is used. The cell-level information is not used. Similarly, only the cell-level information from the files specified in the Cell LEF Files box is used. The technology information from the files specified in the Cell LEF Files box is not used......
the above text has been pasted from solvnet...........regarding database creation from tech files.......what is the significance of the technology section and cell level information used.....?
well, u're talking about load LEF file in Astro to create Milkyway database.
the LEF file contain all the library information as you required. you can get its format on web.
the TECH head define the process information, just as the .tf file in your milkyway library.
the CELL LEF define the cell geometory info for each standard cell.
if you use the .tf file, the TECH head can be omitted when you use the LEF in
in the tech lef files....i mention "tsmc13fsg_8lm_tech.lef" and in
cell lef files ....."tsmc13nvt_macros.lef" for macros.......i guess these both r converted into a single format .tf.......but in the Library i specified .."temp"...i am getting these directories...CEL, FRAM, lib, lib_1, lib_2.........till 7and lib_bck.....
r u saying that we can use .lef or .tf in milkyway database?
as i've said,
"*_tech.lef" define the process info, include poly, mental, via..., it is consistant with the .tf file. so if you use .tf in create library, you can omit this TECH LEF.
"*_macro.lef" define the geometory info of the standard cell macros, which can be converted into the .FRAM view in milkyway database.
as for the .TM view, it's created by the .lib/.db file
