What is the signal strength for RF module 433.92MHz?
aandavan
Full Member level 1
india
hi,
I have a doubt about signal strength. what is the signal strength for RF module 433.92MHz . Help me please...
Re: signal strength
it depends on the distance and the power with which the module transmits and the antenna used for transmitting... without these details it is impossible to find....
Re: signal strength
Hi All,
At system level Signal strength is measured/specified more as a relative term than as an absolute one...i mean we generally express it as a ratio with respect to the Tx signal i.e.,
P(dB)=10log(Pi/Ptr)------(1)
or yet another way is...
P(dBm)=10log(Pi/1mW)----(2)
I mean they generally specify in terms of either equations and Pi is then calculated easily.....!!
Hope it answers your querry.
Sai
Re: signal strength
i am going to add on to waht was posted already that a lot goes into signal strength which are how many watts are you pushing and the hight of your antenna. Those two factors are your biggest concerns.
