What is the setup and hold time?
setup and hold timing
hi nikhilindia85
sorry i couldnt understand which pdf you are referring. I cant see any pdf attachment in your post.
hold time setup
sorry yar.sm prblm was there.here it is
setup time hold
hi,
If you want to know the transistor level eason of the setup/hold time, here is the idea.
On one hand, your data signal has to go through a transmission gate and charge the internal node with the cross-coupled inverters. The clock signal, on the other hand, just needs to "block off" the transmission gate.
Since data must go through more circuitry, it should be stable a little while before the active edge of the clock gets there.
Cheers!!!
setup time hold
pls go through the attached ppt it is helpful for you.
Reactions: vnnavy
    vnnavy
setup and holdtime
Hey guys, if you're looking for the ppt file,
13.SeqCktTiming.ppt
you can get it here,
i really think it helps. better save it before it disappears again!
setup hold time pdf
setup time can be define as the time the data shuld get stabilized before the clock arives.
and the hols time can be define as the max time data should not be launched after the clock passes
definition of hold and setup time
thank you all for the pdf files
concept of set up time pdf
Setup time and hold time constraint is the two main contraints for timing devices. Well setup time is also named the max-delay contraint,while hold time named min-delay contraint.So when computing setup time ,we should use the propagation delay(delay for the new data stable);and for hold time,use the contamination delay(delay for the old data start changing) .In additon , setup time constraint is related with clock period while hold time not.Adding the clock period will improve setup time contrait,but has no effect to hold time.
setup & hold check
You dont consider setup and hold time => metastability in data...
holde setup time
hi go through the following pdf available at the following link
dff setup time and hold time violation
thanks!
13.SeqCktTiming.ppt
setup hold times
with the synthesis perspective, the first statement synthesizes to "MUX" and the second one synthesizes to a "PRIORITY ENCODER"
setup hold checks
The time [before the active clock edge] after which any change in the input data could result in the FF latching the wrong value is characterized as the SETUP time of that DFF.
The time [after the active clock edge] for which the DFF output maintains its value before switching is characterized as the hold time for that DFF.
Added after 14 minutes:
what is setup and hold time?
microe_victor said:
Here is good article about the timing parameters . Hope it is helpful
Thanks for the attachment..Was really helpful
setup and hold time definition+ppt
thanks for the pdf very useful
why setup and hold time
Really nice pdf's are available here which cleared many doubts to me.
Thank u
setup and hold time
Thanks! it really helped me understand...
setup!hold time
do u have the rest of the ppts in that lecture notes:?:
dff setup time
refer to the chapter 7 of rabaey's book for a deep understanding
setup & hold time of dff
I am unable to download the "13.SeqCktTiming.ppt".
What is this point system. I don't understand. I just joined this forum.
Can anybody help me to dwonload it. Or if possible pls send on my mail id (sfdr_imam@rediffmail.com).
