What is the relation between R, C and delay in wire load model?
praneshcn
Member level 5
Member level 5
Hi everyone,
We get R and C values from the wlm's and use it to calculate the delay. Wat is the relation between R, C and delay?
Thank You.
Re: Wire load Model
R = V / i
= (q/C) / (q/t)
= t / C
Therefore t = RC
The product ‘RC’ is called the
“TIME CONSTANT”
This determines the delay of the cell
Hope it helps,
Thanks,
Chinni.
    praneshcn
Re: Wire load Model
hi chinni,
Tanz for ur prompt reply. It helped me really. So based on the product of R and C values the time delay which occurs is known and the total delay calculated, right....................
Tank u once again
Re: Wire load Model
No Probs.you are welcome to ask more q's.
Wire load Model
is it true always?
wire load models...
Re: Wire load Model
the accuracy of the delay will decrease as the length of the wire increases.
