boylesg
- Joined
- Jul 15, 2012
- Messages
- 1,023
- Helped
- 5
- Reputation
- 10
- Reaction score
- 6
- Trophy points
- 1,318
- Location
- Epping, Victoria, Australia
- Activity points
- 11,697
Was thinking a bit about this tonight while I was winding my tesla secondary.
I think I have the normal tesla coil sorted in my minds eye by picturing the anology of pushing your kid on a swing.
The NST or oil burner transformer is a bit like me giving the kid a push when the swing reaches its zenith.
If I push to early or to late then I don't impart the maximum amount of energy to the swing to make it go higher.
The spark gap is much like the pivot point of the swing at the top bar.
So that is essentially what tuning the tesla coil is all about.
You have to match the resonant frequency of the combined spark gap, tank cap and primary coil etc to the NST frequency.
However with a solid state tesla coil they seem to have an arrangement similar to my current flyback transformer driver where a mosfet directly switches the current on and off.
Many of them seem to also have an antenna that picks up RF from the tesla coil and passes it, plus the oscillator signal, through an AND gate of some sort.
I presume this sort of acts like the spark gap restricting the 'push' to the zenith of the current 'swing'
Without the antenna it is a difficult task to precisely match the oscillator frequency to the resonant frequency of the coil.
With the regular tesla coil the match does not have to be quite so precise because the NST is not directly driving the coil - all it has to do in that case is charge the tank cap.
But I can't quite figure out the H-bridge that many people use.
I also not that they are using mains alternating current to drive the coil and have the driver optically or inductively coupled to the mosfet gates for obvious reasons.
My thoughts are that the H-bridge is necessary purely due to their use of alternating current which can only pass through the individual mosfet in one direction.
But they need to let the AC drive current swing both ways through the primary coil.
In which case a H-bridge is not necessary for me because I intend to drive my SSTC with pulsed direct current - I am not at all confident at using direct mains voltage to drive my tesla coil.
Would this, about the h-bridge, be correct?
