My simulation shows the output follows the input exactly.
Likewise when the inputs are switched around.
of course it will work. the point is whether it will do what you think it will do.
so the question is - what do you want it, or think it will do ?
To the Ineffable All,
That is the reason why Bob Pease was wary of Spice. Ratch
Hi Ratch, I am not quite sure if - in this case - we should blame the simulator.
In contrary - the simulation program has made no error.
The user (here: BradtheRad) has selected a simplified and idealized amplifier model without any delay and without any power switch-on transients.
As a result, the program has produced an output signal that can be verified also by hand calculation.
However, the simulation was based on totally unrealistic conditions, and the result is completely meaningless as far as practical applications are concerned.
Here is an illustrative mechanical example: Try to balance one small ball on the top of a larger ball. In theory, this can work - however, everybody knows why it doesn`t.
In summary, in most (if not in all) cases it is the user who makes errors (false inputs, false interpretation of the results) - not the program.
If the transistor is ideal then Vin will equal Vout??? ..
which transistor are you referring ? or is this a new question?
if you mean opamp, then you have to interchange the + and - inputs in your circuit. then it will work even for non-ideal practical opamp.
Sorry .. Yeah, I mean op-amp ..
Without changing anything using an ideal opamp .. What would be the relation between Vin and Vout? ..
If you tell me where to buy an ideal Opamp, I'll answer your questionWithout changing anything using an ideal opamp ..
If you tell me where to buy an ideal Opamp, I'll answer your question .
The output voltage is:
Vo = Vi / ( 1- 1/A) where A is the open loop gain of the op amp. so A>>1
you can disregard 1/A then you have.
Vo=Vi
That is a voltage follower. In theory the same as the standard one with negative feedback.
This is what the simulation of BradtheRad shows.
But in practice it will never work for the reasons that have been discussed before.
Yes, but why don't you try in a simulation yourself? We know because we did before.If the Op-amp is ideal .. ( I+ = I = 0 ) and ( V+ = V- ) .. Then , Vin = Vout in this circuit ..
and if it is not ideal ,, the op-amp will be saturated and the Vout will be equal to the value of the external power supply ..
right?
