What is the minimum supply voltage for Op-amp IC 741
sagar_echip
Newbie level 6
Newbie level 6
op amp ic 741
What is the minimum supply voltage that can be applied to op-amp IC 741?
ic 741
Supply-voltage operating range for the 741 is
+- 4.5 volts (minimum) to +- 18 volts (maximum),
for more info see following link
Regards
ic741
check the datasheet of the specific manufacture
