What is the meaning of Sub-Harmonic Mixer?
No one
Full Member level 5
Full Member level 5
Hello Everyone;
mixer [hlp]
u sample the data with f < fmax , this will result in the translation of the signal to baseband , but to prevent aliasing u must keep f > 2B (where B is the channel BW) , but this technique suffer from the noise folding
mixer [hlp]
please refer to one paper about sub-harmonic mixer in ISSCC2006,you can search it in ieee
Re: mixer [hlp]
In a simple words, isn't a sub-harmonic mixer a mixer, where LO signal's frequency is a sub-harmonic of the LO signal's frequency of the conventional mixer?
Suppose you mix RF 10GHz with LO 9GHz (IF 1GHz) with conventional mixer. For sub-harmonic mixer the LO would be, let say, 3GHz and you would still get IF of 1GHz due to the hamrnonic mixing.
    No one
mixer [hlp]
sorry , i seem to make a mistake i thoughtt u meant sub-sampling mixer , anyway i think rfmw is correct , sorry for any confusion i caused
    No one
