What is the meaning of at-speed testing?
wanzuha
Newbie level 3
What is the meaning of at-speed testing. it is system speed ?
Re: At-speed testing
at speed testing means is a test mode that needs the ATE to test chip at this chip's real work clock frequecy.
    wanzuha
At-speed testing
What will happen if i'm using bist
Do you want to test memory or something else ? If memory, then BIST is the cheapest and more reliable solution
in at-speed testing, launch will happen at hips frequency, but capture will be at slower rate. at-speed testing will give more about transitions, rise, fall and other speed effecting defects.
For BIST, it means BIST run at real clock speed. The clocks may come from PLL.
At-speed testing
yes
normally test clock is very slow,
so many problems cannot be found at test clock
at speed test is system speed
yes. at-speed test means test the design at its system speed.
Bist test for memory of IP blocks are usally at-speed (they will design to run at system clk speed).
For scan, the at-speed test happens with at-speed launch and capture during scan_enable pin low.
