A silicon n-cannel depletion mosfet is built around a single p-n junction, which you can't forward bias. Being so, Vgs must be negative or zero. You may make it slightly positive by a few tenths of volt but, as you know from a simple diode, it will start to conduct soon.
what is the maximum value of n-channel depletion mode mosfet when it work in the enhanced mode?
You are referring here to a JFET. Depletion mode FETs don't use a reverse-biased PN junction to create pinchoff, but rather they have an isolated gate. This means Vgs can be greater than zero, causing channel enhancement.
