What is the max. allowed data rate at the 868.35MHz band?
Mac7978
Member level 2
Member level 2
Dear all,
Happy new year.
I am designning a 868MHz RF modules, but i am not familiar with the regulation of this band (868 - 868.6MHz). If ASK and FSK use as the modulation technique, so what is the max. allowed data rate of them, respectively? Hope someone can teach me,,,thank you.
best regards
Mac
Re: What is the max. allowed data rate at the 868.35MHz band
I don’t think is a requirement for this, since you are in band limits. This is the reason that is an ISM band. ZigBee use 250 kb/s in this band.
There are theoretically/in general no limit for the data rate at this ISM band. However, the duty cycle, transmit power, etc. regulations and modulation bandwidth, BER requirements of your application put certain limits on the maximum data rate in practice. You are in principle free to trade these parameters.
Example: IEEE 802.15.4 / Zigbee at 868 MHz
The data rate is 20kbits/s, but the chip rate is 300 kchips/s.
Good luck with your project!
All the best
ZigBee data rates:
868MHz
20 kbps (1 bit/symbol, 20 kBaud)
Data modulation is BPSK with differential encoding
Spreading code is a 15-chip m-sequence
Chip modulation is BPSK at 0.3 Mchips/s
Low rate for better sensitivity and larger coverage area
2.4 GHz
250 kbps (4 bits/symbol, 62.5 kBaud)
Data modulation is 16-ary orthogonal modulation
16 symbols are ~orthogonal set of 32-chip PN codes
Chip modulation is MSK at 2.0 Mchips/s
High data rate to attain high throughput
The maximum spur emmisions are limited too. See page 4 of the attached document.
Al
