What is the main use of PERL in VLSI?
Guru59
Full Member level 4
Full Member level 4
hello everyone
i was asked in an interview about PERL....
i am basically an electronics graduate looking for opportunities in VLSI
what is the main use of PERL in VLSI................
if anyone has such docs it would be very great if you post it...or else atleast some one plz say where can i get such information abt PERL in VLSI..........
perl for vlsi
PERL is a scrpting langauge and normally used to automate task.
So to run vlsi tools or testbench stuffs rather then doing things manually u write a script for runing the task.
perl vlsi
can you be more specific...
in the sense do you have any material realting or writing basic perl scrips for VLSI............
vlsi perl scripts
Hai Guru..........
Basically PERL is used to script the command prompts in Tools..............
if you want to go for scripting in PERL search for books on PERL here in the ....
Good Luck..................
    Guru59
application of perl in vlsi
Guru59 said:
hello everyone
i was asked in an interview abt PERL....
PERL:practical enquiry and reporting language .Its a scripting language.IN verilog mainly in verifying instead of doing things manually scripting makes things easy
Go to oubook.com abd u can find lot of books
perl tutorial for vlsi
Hi Guru,
As the other poster mentioned, PERL is a very handy tool in VLSI design in all phases. In Verification this is very heavily used in almost all design teams/projects. Learning PERL itself is not so difficult (several good online texts/links/tutorials exist), do a google search. Infact in our company every engineer is required to learn Perl and use it in real verification project as most of our customers demand that.
In our recently launched Comprehensive Functional Verification (CFV, see: www.noveldv.com) course, we show real life applications of PERL in Verification. The course doesn't really teach Perl by itself, as the scope is different.
HTH
Ajeetha, CVC
www.noveldv.com
perl+vlsi .pdf
you know, perl is good for text processing. so, it's very useful for automatical codes generation, or in scripting in verification.
perl fo vlsi
ya... perl is very useful in VLSI...
but in my opinion... interview for VLSI post wont require u to know about it as perl is used for automation..
normally they will ask u on both transistor level and logic level design... i think u should focus on these rather then the scripting...
sp
why do you prefer perl in vlsi
here is a elaborated answer -
1. In schools and colleages, the vlsi tools used will be generally GUI based. You do design, compile, simulation etc with the help og GUI.
2. In practical, guys in companies prefer to use command line intarface of the vlsi tools. they create scripts to call these command in a sequence. Now in order to add more automation they provide comman line options to such scripts.
3. PERL is one of languages that can be used to create such scripts.
4. PERL can also be used to check status of programms by comparing godlen results with present results.
5. PERL is also used to create some conversion scripts. e.g. your vhdl code is reading some text file. Now if the format of data with is different that what the vhdl code exepcts. Then you can crate a perl script to convert you data in to the required formated text file.
In my opiniun a very small set of perl language is used for VLSI.
hope this will help you.
Best luck,
Ramchandra
Reactions: melkord
    Guru59
    melkord
perl and vlsi
Hello Guru59,
To master Perl, follow these steps and in shaa allaah you will be Perl professional;
- Get the source of Perl from www.perl.com (if you work under Unix, most propably you will find it already installed)
- Start by a quick Perl tutorial to take an overview (a deep overview) .. this one is greet choice: www.comp.leeds.ac.uk/nik/start.html
- Then read further small book in Perl to get deeper inside .. I suggest: "Perl in Nutshell"
- Try to solve some Perl practical problems, a good problem are made in the: "Perl Quiz of the week" wonderful site here: perl.plover.com/qotw
This is enough, after you join work, you will practice more specific things, and may need a reference to refere to it when needed.. such as: "Programming Perl", Larry Wall, Tom Christiansen & Randal Schwartz. (The camel book.)
I hope that helps you...
Best Regards,
Ahmad,
Re: PERL in VLSI....................
Can any one let me know where I can get the sample PERL Scripts or could any one share one... please
Thanks
Vinod G
