What is the logical function in Matlab?
deepu_s_s
Full Member level 5
Hi friends,
Can anybody clear my doubt ....
What is islogical function in matlab.. Please explain me in detail...
Is float is the default data type in Matlab?
Thanks and Regards
Deeapk
Re: Doubt in Matlab
islogical - function
write down on matlab command prompt
helpwin islogical
you will get detail explanation
Doubt in Matlab
Many MATLAB functions and operators default to double (double-precision floating point), but some functions and operators work with other object types too. For example, if you type 2+2, the answer 4 will be double. If you type x=int8(2) and then x+x, the answer 4 will be int8.
If you wish to identify the type of an object, try the 'class' function. For example, class(pi) returns the string 'double'.
Re: Doubt in Matlab
from Matlab help:
"ISLOGICAL(X) returns true if X is a logical array and false otherwise.
Logical arrays must be used to perform logical 0-1 indexing."
eg.
>> x=[0 1 0 1 0 0 1]
x =
0 1 0 1 0 0 1
>> y=logical(x)
y =
0 1 0 1 0 0 1
>> z=islogical
z =
in workspace, y and z are both logical class,...
For the second question "Yes", float is the default...
Doubt in Matlab
it means that the array will contain only binary 1s and 0s.
So the array which contains that kind of elements is known as logical array. Is that right?
What is logical class
Doubt in Matlab
Open your MATLAB help navigator, and search for "logical types".
It explains that data type, and gives various examples.
Doubt in Matlab
best way to learn the matlab is the matlab help file and the matlab official site www.mathworks.com
Re: Doubt in Matlab
HAI zio_nneo,
YES what he said is correct and easy method for learning matlab
