What is the function of P4 and P2?
rx5
Full Member level 2
Full Member level 2
Hi all,,
I have scheme here... i forgot WHERE i have downloaded this .. here goes..
What is the function of P4 and P2???
could someone translate the text??
thanks a lot....
function gen help..
Hi
I dont know germany language but as i see in diagram i think:
P2 change output duty cycle and
P4 change triangular amplitude.
function gen help..
Hello Davood,
hmmm.. so I assume P1 would be the frequency adjustment :) as P2 is the duty cycle control....
looks like ill have 2 controls for triangle amplitude control..... P4 AND P3.... :)
am I correct??
anyways, ill do give the circuit a try..... :)
Re: function gen help..
Hi
as you said P1 adjust frequency.
and P4 adjust amplitude of all 3 waveform
whereas P3 adjust triangular amplitude
regards,
function gen help..
hello Davood,
P4 also adjusts SINE amplitude? since it takes a part of the triangle to form sine.... :)
btw, I forgot to ask, whats the use of S3????
regards
-ralph
function gen help..
Sine wave amplitude limited with D1 and D2.
i think S3 select which portion of wave to act on duty cycle adjustment (i mean high or low value of square wave ).
