What is the format of spectre model files?
ASICK
Junior Member level 3
san jose,ca
How to use Spectre
What is the format of spectre model files? how do I use spectre, as each time I try to run it I get a message saying I need to convert SpectreS model siminfo to spectre using toolbox, but that doesnt work, is there a way around? like specifying my own .25u libraries and giving that path to spectre? Or is there any way to do PZ(pole zero) using spectreS as thats the only simulator I can use in Cadence, please help, I am stuck....I am using TSMC .25u from NCSU
How to use Spectre
have you set the right model path?
did you choose the right model for your design ?
which models are provided in TSMC .25u from NCSU?i haven't use this library,but i have use .25u library directly from TSMC,just symbol is ok for simulation using spectre.
How to use Spectre
Most of foundry all support the models for Spectre. So it is un-necessary to convert it to other format. Use the ADE and add the model in model path.
