What is the effect of leakage power on threshold voltage
vlsitechnology
Full Member level 5
Full Member level 5
Hi Can anyone tell me how leakage power is directly proportional to threshold voltage?
I think it has to be inverseley proportional because Leakage current is inversely proportional so power will also be inversely proportional right?
Hai
Higher the Vt lower the leakage delay more.
This ststement explains u all.
enjoy.
Santu
That means the leakage power is less when the Vt is high and when Vt is low the leakage power is less so according to ur statement it is inversely proportional am i right?
hi vlsi
on time Delay of any transistor depends on the threshold level,,if th is more then it takes more time to turn on so the delay of that cell becomes more,,, on the other hand to get more Vth need to dope the substrate heavily which decreases the minarity careers by which the leakage power comes down,,,,,,
SO HVT CELLS GIVES LOWPOWER AND LOW PERFORMANCE
Reactions: vid31
    vid31
Hi vlsitechnology,
Vt and Leakage current is inversly proportional. So for transistors with low Vt , we have higher lekage current and vice versa.
regards,
sp3
