what is the easy simulation software for power electronics??
satya_vijayawada
Full Member level 2
Full Member level 2
hi
which is the best and easy simulation software for power electronics?( UC3525, UC3844,UC3854,....Fly back,PFC ,boost ,push-pull ..... etc)
and also how many software available for power electronics ( SMPS, UPS design support )
Regards
satya
LTSpice has, i believe, the biggest range of pwm controllers for you, i beg you to forgive me if i am incorrect
Re: what is the easy simulation software for power electroni
Simulation software is based on the process of imitating a real phenomenon with a set of mathematical formulas. It is, essentially, a program that allows the user to observe an operation through simulation without actually performing that operation. Simulation software is used widely to design equipment so that the final product will be as close to design specs as possible without expensive in process modification. Simulation software with real-time response is often used in gaming, but it also has important industrial applications. When the penalty for improper operation is costly, such as airplane pilots, nuclear power plant operators, or chemical plant operators, a mock up of the actual control panel is connected to a real-time simulation of the physical response, giving valuable training experience without fear of a disastrous outcome.
Advanced computer programs can simulate weather conditions, electronic circuits, chemical reactions, mechatronics, heat pumps, feedback control systems, atomic reactions, even biological processes. In theory, any phenomena that can be reduced to mathematical data and equations can be simulated on a computer. Simulation can be difficult because most natural phenomena are subject to an almost infinite number of influences. One of the tricks to developing useful simulations is to determine which are the most important factors that affect the goals of the simulation.
In addition to imitating processes to see how they behave under different conditions, simulations are also used to test new theories. After creating a theory of causal relationships, the theorist can codify the relationships in the form of a computer program. If the program then behaves in the same way as the real process, there is a good chance that the proposed relationships are correct.
easiest is PSIM. it is only good for functionality, not detail design. i.e. this is the same as simulink.. but simulink also has incredible amount of features if you want more complexity...
Mr.Cool
