I do not know which RTOS is better for a 8 bit microcontroller but I think your selection should be an open-source free RTOS. so that you can go into it's depth easily.
is SALVO free?
hi all
wat karan said for micro controller rtos is the best approach i had gone through
better go to www.pumpkininc.com and chek ther u will get all info for pic and other controller its the best ,u can get free download of salvo but u wont get complete lib that u can use max
Hello,
You need to define 'best' before you ask a question like this. What platform are you using, and what development tools? Do you want to spend money on it? Generally the free RTOSs are more difficult to use, but the commercial ones cost a lot of money. Some compilers come with an included rtos which may be enough for your needs. Some posters here are giving you OSs which are for 16/32 bit processors 'RTEMS,' is one example.
The best advice I've seen here is for uCOS II, because as you build it, you can read about it, and gain understanding of how to use it well. That being said, picOS18, or freertos, is probably worth looking into. SALVO has a demo version, that is probably the quickest to get up and running.
Most likely, you can get by with a simple scheduler, which you can write yourself. RTOS is well suited to apps where timing is critical: auto-pilots, and medical equipment, where a failure in timing can spell disaster. For almost all hobby projects, a scheduler is enough.
Just my two cents,
Robert
UCOS has a problem,it is not round robin,we can not have tasks at the same priority and executes them periodically.
How do you solve this problem in UCOSII?
UCOS II also need more ram ,for example ATmega64 with 4K Int RAM is not enough for UCOS-II ,we need to add external RAM ,what is your idea?
>UCOS has a problem,it is not round robin,we can not have tasks at the same >priority and executes them periodically.How do you solve this problem in >UCOSII?
Please tell me when you want to build the same priority ? so i can show you.
For my case like 4 pcs Seven Segmen showing and 4x4 keypad. Using the same I/O which one priority is important ?
I think it's same. You can set seven segmen showing at high priority and ISR at keypad.
Or at the same task can do two perform two process.
In theory we can said this more weaker than other. in real world i think ucos is enough.
You can close some var if you not use. such flag semaphore or others that's u are not using for the application. RTOS only recommended for 16 bit or upper. is it ATmega64 is 16 bit or 32 bit ?
As i know RTOS using for handling complex task. For simple task you can use manual one. State process or other technique.
