What is the difference between psynopt and place_opt commands in ICC?
vterminater
Junior Member level 1
My confusion is that i think both commands do the same. place_opt : optimizes placement of cells to improve timing, congestion. psynopt : Does incremental optimization of cells to improve timing and congestion. Then what is the difference!!? Is it the way they work? Please help me out on this.
psynopt is for further fine tuning of design apart from place_opt
Place_opt*(works on physical aspect,{placement, buffer insertion, removal})
Psynopt: Incremental Logic Optimization (like synthesis :works on logic)
Is the above right?
This will help me understand the concept behind these commands, also if i can skip place_opt and run only psynopt or vice-versa.
I think place_opt doesnt do buffer removal,there is separate command for it.
