thotamail
Hi All,
Can any one explain me what is the difference between Noise Density(ND) & Noise Floor.
According to definitions
1# "Noise density is defined as the average noise power in 1 Hz bin",
that means wide band noise when spread across the Oscilloscope Bandwidth, each 1Hz bin will have a noise of "ND". Isn't it?
Also explain me the difference between dBm to dBm/Hz conversion
lets say a signal of power 0.1uW = -40dBm, Can you convert it to dBm/Hz
2# "Noise floor is defined as the average noise power in “setup specific” bin"
Please can you detail me on this
Thanks & Regards
Vamsi Krishna Thota
Thanks & Regards
Vamsi Krishna Thota
