What is the difference between #define n 100 and int n=100 ?
fatma1000
Banned
Full Member level 2
eygpt
help2 in c++
what is the difference between
#define N 100
double H[N];
and
int N=100;
double H[N];
help2 in c++
hi
secound code does not works
cuz when u declear an static array compiler should knows the dimention of that and in this condition the value of N is unknown in compile time until run time.
but in first code u use from precompiler expresion #define that is same as u write int H[100];
if u want to create an array with dynamic dimention use from new and delete operations.
int *H=NULL;
int N=100;
H=(int*) new int[N];
use from H like an array and when u dont need it any more. u should free memory of it:
delete[] H;
H=NULL;
help2 in c++
int N=100;
double H[N];
this will not work, however
const int N=100;
double H[N];
this will work and the difference between
1)
#define N 100
double H[N];
and
2)
const int N=100;
double H[N];
in case 1, the compiler simply replace the N with the number defined and compiles the code, this is done during the precompilation phase of the compiler
in case 2, the compiler compiles the code as it is and i would recommend this because the code is more type safe this way.
