What is the coner simulation and how it works?
wangse
Newbie level 1
Newbie level 1
corner simulation + berkeley
I do not know exactly what coner simulation means.
How to set the resistor, cap, mos value in each case.
Please let me know about coner simulation
.alter + corner simulations
Usually the spice file provided by the foundry contains this information. All you have to do is specify which corner (TT,SS,FF, ..) you want to run simulation.
Re: coner simulation
running corner simulation means running cases with variations in temperature, process parameters and voltage supply.
Go thru the foll link
chethan
coner simulation
let the process all in the corner that make it fast/slow
coner simulation
On the other hand, u still simulate the schematic as the following:
resistors : change +/ 10%
coner simulation
It is different in the model select (TT FF FS SF SS).
coner simulation
you can .alter change the corner when you run sim.
coner simulation
What are the corners, i.e., FF/SS/SF/FS, usually simulated along with the TT one? And how about Temp=?
If you have the lib set of hspice! you can do simulation.
coner simulation
If you use cadence analog environment, you can use ocean to run corner simulation
The lib document provides you abundant information,so read carefully whenever you begin a simulation.
The attachment is an example from Berkeley...
Your corner should include :
SS-FF-SF-FS for high-low temperature for high-low VDD, i.e. : 4x2x2=16 simulations!
If you include resistors Slow-Fast and capacitors Slow-Fast, you get 64 simulations ...
The guru of your company should setup trade-off to reduce them, otherwise ...
... use .alter command and wait for 1 night !!!
