What is the coat film?
tony_lth
Advanced Member level 5
Beijing
Is it possible to coating a pin to make RF pass through, and make DC block?
It is more reliable to put a capacitor in series with it. The friction and rubbing from plugging and unplugging will remove any film.
Seems like a cool trick, espassialy if you dont have to plug/unplug very often
Someone who tried this, how much insertion loss ?
I think you can not use at low frequencies...
For maybe higher frequencies..
I saw one product of one China Nanjing verdor. On pcb trace, there is a coat, then pin was soldered on, but DC is blocked, and I guess RF is shorted. I will measure later and let you know the results.
I tested it today. The pin is really RF shorted to GND and DC blocked, with DC=0.35V. I guess that they use some glue, who can suggest that?
And I simulate in HFSS about the epoxy of FR4, its insertion loss less than 0.1dB when epoxy thickness is 0.1mm.
